aarixx3
- 5
- Dec 8, 2013
Boca Raton,
Florida
So, i've been looking for a dsm for a while now, i wanted something clean, automatic and stock ish. Then this 2g Gs-t popped up for $1500. I was first to see the car, figured what the hell this would be easy to flip even if it has problems, so I bought it. Well, I keep getting the urge to build the car up instead of selling it, but i am lost on where I should start. Buffed out the paint, fixed door handles and oil leaks. Now its leaking water/coolant, lifters are ticking after an oil change, has bad tires and my compression test is coming up as 178, 165, 172, 120. First cylinder is the culprit, and it tested 130 wet. Oil pan was extremely clean, no shavings just kinda beat up. It has 129k miles, 97 Gs-t, stock other than BoV, my plans were to have a quick and clean 2g DD with reliability in mind! But my question is where should I start? Most likely need to take car of the low compression cylinder first, should I get someone to help diagnose and fix it myself, machine shop, send it to a shop, buy a new engine, etc? Any advice or input is much appreciated!
First bought it:
Buffed out:
First bought it:
Buffed out:
