boostforfun
- 184
- 2
- Apr 1, 2004
Glenwood,
Iowa
Just did some exhaust work on my friends car, then put wideband on, its reading 13.5 at 13psi pull in third.
The car is a bone stock 90 FWD except K&N filter, 7cm exhaust housing on 14b, evoIII o2 housing, 3" turboback exhaust with dynomax muffler.
The car had no resonator, and was creeping to 16-17 psi, but was really droney, so we put a 30" glasspack in it to help with drone. Now it only spikes to 13psi.
However, after the glasspack install we put in a AEM wideband, and discovered that it is reading 13.5 AFR at 13psi on the top end.
I told him to do no more pulls until we can get this sorted out. I am taking my logger over this weekend to look at it.
Any initial ideas on why so lean? It must be fuel delivery. I am going to recommend to him a fuel filter change and rewire the pump. But still... that seems REALLY lean for that amount of boost, even with the 7cm ported housing and ported E3 o2.
Another thing I remembered; I guess it has the lower honeycomb removed from the MAF
