El Cuervo
- 576
- 25
- Nov 7, 2004
Omaha,
Nebraska
Hi guys.
I'm having a little problem here in regards to finding some power source wires.
I'm looking for a Constant 12v power source and an ignition only 12v source for some electronic gauges.
I found three 12v wires with my multimeter. They are 1 red wire that connects to the radio, 1 yellow wire that also connects to the radio and the blue with white striped wire with a green connector that connects to the actual cigarette lighter.
Here is my problem.
With the battery connected and with the car turned off, I placed the negative lead of the multimeter to the metal frame behind the radio for ground and the red lead to each of these wires.
Well, they all show about 12 volts. The cigarette lighter and the 2 wires that go to the radio.
It seem like these are constant 12v wire sources because the car was off with no key.
So how do I find an ignition only 12v power wire?
I thought that the cigarette lighter was an ignition only power source. I tried using the cigarette lighter with the key off and it did not work. So I turned on the car all the way to start but did lot started the car and tried using the cigarette lighter again. This time it did work. This is when I thought that I had found my ignition only 12v power source.
Well, when I diconected the wires from the cigarette lighter and checked for voltage with the car off, I got 12v or so of power with the key off and with the key turned on. I thought that I was only going to get a reading of 12v with the ignition on and NO voltage with the key on.
Am I doing something wrong here?
How can I tell from a constant 12v power source and an ignition only 12v power source??
Thanks guys.
Here is my problem.
Thanks guys.
