1. Join the Community!
09 Impala I/P died while driving after new bat and alt.
Posted by 3Burritos, Dec 1, 2019
Please Support ExtremePSI
Please Support Feal Suspension
  1. 3Burritos
    3Burritos Probationary Member
    Joined Dec 1, 2019
    Tulsa, Oklahoma
    Hey guys, total car noob here and cannot find any info anywhere about this...
    In the last 3 days I have replaced the battery and alternator in my 09 Impala I/P with 140k miles on it.
    Tonight when I went to flip the high beams on, my car died and after the panic of no brakes or steering and no shoulder to get over, it started back up with no issues minus battery svc mssg and battery light. I got home and checked the battery because my mom suggested maybe it was the wrong one and this one is CC 600 and like RC 120 whereas my old one was like CC 1000 RC 900. Could this be the problem? I don't even know what to do anymore and so broke after all this that it hurts.
    Sorry for being ignorant and tyvm for your time and expertise beforehand.
  2. buddahboost
    buddahboost Proven Member
    372
    62
    Joined Aug 15, 2007
    CHICAGO HEIGHTS, Illinois
    Bad ground. Make sure they are clean. Are the battery terminals clean as well?
    If you turn the car on and disconnect the battery, does it shut off? Might be a bad alternator.
    Street Build 111  1
    1992 Mitsubishi Galant VR-4
    awd · automatic · Galant VR-4
    Loading...
    1990TSIAWDTALON and lglracer like this.
  3. BLACK'98DSM
    BLACK'98DSM Proven Member
    1,555
    630
    Joined Feb 9, 2019
    Hoover, Alabama
    It could also be ecu problems, but lets try everything else first.
    Road Race Build 3K  10  25
    1998 Mitsubishi Eclipse N/T
    fwd · manual · 2G DSM
    131  3
    2008 Tomberlin Crossfire 150R
    rwd · manual · Misc Vehicles
    168  6
    2008 Tomberlin Crossfire (325 swapped)
    Loading...
  4. rabenne
    rabenne Proven Member
    1,345
    504
    Joined Apr 21, 2006
    Racine, Wisconsin
    Your battery should be rated at 600A CCA for 3.5L, 750A CCA for 3.9L or 625A CCA for 5.3L.
    If you have the 3.5L your battery is correct. If you have a different engine, it is slightly undersized.
    That shouldn't cause it to shut off. You may have a bad connection at the battery (due to corrosion) or somewhere in your starting circuit or ground circuit.
    Check both ends of the starter wire for corrosion - clean them up - and tighten everything back up. Do the same for the battery terminals.
    From there, we will probably need to do some testing with a voltmeter. do you have one/access to one?
    306  7
    2008 Lancer Evolution MR
    awd · automatic · Lancer Evolution
    Street Build 8K  19
    1995 Eagle Talon TSi
    awd · manual · 2G DSM
    Street Build 505  5
    1996 Mitsubishi Eclipse GSX
    awd · automatic · 2G DSM
    Loading...
  5. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    5,394
    2,697
    Joined Nov 14, 2013
    Independence, Kansas
    @buddahboost and @rabenne have some very good recommendations. Make sure that all connections are tight and clean.
    Street Build 4K  29
    1992 Eagle Talon TSi AWD
    14.74 @ 117.04 · 1G DSM
    1K  14
    1990 Mitsubishi Eclipse GSX
    awd · manual · 1G DSM
    755  18
    1967 Chevrolet Camaro RS
    rwd · automatic · Misc Vehicles
    Street Build 1K  7
    1998 Eagle Talon TSi
    Street Build 6K  13  25
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 · 1G DSM
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
