krazywhitboy
- 339
- 0
- Mar 4, 2004
NorCal,
California
just wanted to get you guys opinions here.....should i just rebuild my exsisting motor, or buy a used japanese one? i found a rebuild kit for $419 (includes complete gasket set, pistons and rings, main bearings, rod bearings,thrust washers, timing belt, balance shaft bearings, and oil pump.) i can upgrade the main and rod bearings to TOGA high perf bearings for another $40. rebuilding the engine won't be a problem, i know what im doing (mostly....). oh, and i found a website that sells 4G63T 6 bolt motors with 40-50k on them for $960 (yes i made sure that price was for the turbo motor....)...should i go for the japanese motor, or just rebuild mine????
