Only in a DSM
Originally posted by InfamousEclipse
My blinkers wont work when my headlights are on, but if I turn off my headlights my blinkers work fine.... WTF? :confused:
Only in a DSM...
I had the same problem when I switched my bulbs to LED's, so I flipped them around and they worked fine. But if your using regular bulbs I don't know what to tell you besides check to make sure the wires are in good condition and the grounds are solid.
sometimes my blinkers just stop workin so to get them workin again i have to push on emergency botton (the red triangle thingy) litly and it works perfectly fine after that!!!! :confused:
i rememembered another thing, after u take the key out of the ignition u can still use powerwindows and sunroof... i dont think i was able to do it on the other cars...:thumb:
Having the bolts for your starter that you had torqued and tightened with loc-tite back themselves out completely 36 hours after said torquing and loc-tightening was done....
Only in a DSM:talon:
when after your battery dies one night, the car flashes its 4 ways non-stop for over a month (and still counting) whenever you drive it. still can't figure this one out.
You have to beat off girls with sticks while cruising down the street
:Only in a DSM:
Your timing belt slips or breaks and you need your heads rebuilt
:Only in a DSM:
LOL keep this going.
My 1G has a stick to prop the hatch, my 2G hatch went out, out of nowhere... what an inconveneince.
Now my blinkers work fine, is it possibly a problem w/ the alternator?
Not being able to find a decent one after 2 months of searching :( .
OMGnly in a DSM:
Only in a DSM - pushing down the pedal and actually feeling the car go slower... god damned phantom knock
Originally posted by wishihadatalon
takes a whole month and over $500 in parts to do a axle replacement.
Huh? :confused:
I replaced both of my front axles for just around $300 ordering them brand new from Raxles and had the whole job done within a week.
: only in a DSM :
it took me almost 6 months to find my 1g awd. well, i found others but they were ALL SOLD like within 24 hours of being listed.
