problem with airintake on a 1990 plymouth laser
punkreeves
20+ Year Contributor
68
Aug 25, 2002
Amanda_Ohio
i want to replace the stock air in take on my 1990 plymouth laser with an air filter or cold air intake and get rid ofthe huge box inside. but when i unplug the air sensor the car won't run. How do i use a new cold air intake or filter and have the car still run. the sensor is right on the box and to add the cold air intake or the air filter it needs to be removed?
You have to have the MAS on or the car will not run. You could get a VPC if you want to get rid of the mas all together.
i got mine to run without the MAS for like half an hour. all you gotta do is keep your foot on the gas all the time and put it in neutral when you wanna stop.
thanks fore the info guys but if i buy a cold air intake for my car do i have to buy special parts to get it to work or will the cold air intake for my car have everything i need??
Have you thought about hacking the stock air canister and just putting a K&N in your car? I did this on both DSMs that I have owned and gotten noticeable differences both times. I also removed the silencer from the back of the MAS. You can hack that thing till there is only enough to hold the air filter in there and let it just rest in there. There are numerous web pages out there that show you how to do this free mod. Check the tuning section out here.
