Problems after 550 install(Please read)
91TSI505
20+ Year Contributor
256
Jan 10, 2003
Albuquerque, New_Mexico
Ok so i got my 550's,installed them and the car runs like shit!I leaned out the translator according to the injectors,double checked my install and everything i could think of.I ran out of light so i called it a day.Next morning i go out to start working on it again and someone broke into my car and took my AFC,Gauges,stereo and broke my window:mad: So i rewired the ECU back to stock,i do a little more research and find this:
I start the car and pull of the electrical connector to the fuel injector on cylinder 4 and nothing happens(like the fuel injector is not given any signal),same thing on cylinder 2.When i pull them off of 1 and 3 the car dies,so those seem to be fine.The plugs were just changed,i also checked the plug wires and those were fine.Just to make sure it was not the injectors i swapped the 450's back in and the same thing happened,the only thing i did during the install was unbolt the fuel rail and unbolt the fuel feed to the fuel rail,i am stumped and have no idea what to do now,any help would be greatly appreciated,Thanks in advance.
ok its called an open circuit.... First off a car Will run on 3 cylinders(just not right). You might have a open in the in the circuit, bad connector or something along those lines. Did u pull the connectors off when the car was running? if so thats not good...and also did u notice any problems with the car running crappy before the install?
No the car ran great before the install,yes i did pull it off when the car was running.i don't understand,i did not touch anything except the injectors and the fuel rail in the process,how could something else go wrong?coinsedence?
wires were in the wrong firing order,LOL!!!The stupid things we do:D
