dsm023
- 69
- 3
- Mar 3, 2004
Orlando,
Florida
Razo
WMD said:I have that exact shifter, it works great and it feels like I can shift just as fast as an auto.
But and it comes with a big but, I had to re-engineer it so it would work.
First off:
The pivot point rod is screwed into the shifter. So, by using your imagination you can guess what happened, it unscrewed during shifting and became wobbly. Cold weld (a two part automotive resin) fixed this problem. It has a tensile strength of 30,000 psi (I believe).
Second:
It did not come with a bearing to fit inside the pivot point raiser (purple thing). The pivot point rod has a smaller diameter than the bore in the pivot point raiser, so that was loose and wobbly. I had to make my own bearing out of two brass tubes and grease.
The tubes can be found at hobby shops or at a hardware store (found mine at ace)
If you get it, well, good luck!
Edit: or you could find actual bearings to fit inside, I did not look into this option for some reason.
DSMcrazy3 said:I haven't seen anything bad about the knock-off B&M's...I have a knock off and a few other people have them also. No problems...
Try to search before posting next time, as stated, this question was just asked the other day.
Here's a link to one that will work. Any other ad's with the same looking shifter should be fine.
http://cgi.ebay.com/ebaymotors/95-9...064742241QQcategoryZ33736QQrdZ1QQcmdZViewItem
DSMcrazy3 said:Seriously, I would not pay $100 more for a genuine B&M.
