Raddeling while floored
Stony
Feb 18, 2003
Palatine_IL
when I accelarate harder the sound of the car sounds like raddeling or something like that, its hard to explain, but the weird thing is that it only does it sometimes, sometimes its fine. I dont feel any loss in power though and it didnt used to do it, so I think that theres a problem!
Originally posted by Stony
well, it defenetly helps me, gives me new ideas of what might be wrong and your thoughts on mechanics are real good, ...
you should try to learn some Estonian. At least look into it, and let me know what you think.
But I'll keep you up to date. Thanx again for all your support, and I will talk to you later.Sincerely,Stony
Thank you for the compliment, you are welcome. Now I understand "Stony" has nothing to do with drug reference. :)
My dad was a prof. of foreign languages, I can muddle through most of the Romance languages in a newspaper or automotive technical publications but that's about it. You start talking Slavic or Russian forget it, I'm out to lunch.:) Cars, boats, motorcycles, physics, and electronics I can understand even with a language barrier.
Let us know what they tell you> Diagnosing symptons is little different from what a Doctor does, it's an art form which is based much of the time on years of experience.
And much lacking in the practice of mechanics is a reasonable "bedside manner" which is also harder to find in medicine these days.
Before you left Estonia, who made more money, Doctors or Mechanics???
Cheers,
GTM
Cheers,
GTM
I'm pretty sure it was doctors, but most of them dont know what they are doing.
Some 10 years ago I'd read that mechanics made more money in Russia for the push in the ecuaction field was to produce a highly qualified technical population but they failed to realize they needed a backup to do the actual work. This resulted in the need to import labor from other countries because they had not bothered to encourage advancement in the actual physical skills necessary.
Back to the topic at hand, any progress?
Cheers,
GTM
Cheers,
GTM
I'm going to the mechanic tomorrow or this weekend!
I went to the mechanic, but the bi*** ran fine when we went to the test drive, but I explained it to him and he told me to check the drive shaft connections, like go under the car and see if its loose at all. I havent done that yet, but I'll keep updating the status.
Stony
