looking for Garrett 4 bolt 3" o2 housing
jdmawd
Banned Member
3,324
Mar 20, 2002
GreenBelt, DC_Metro
Pretty much like the title says. im looking for a Garrett 4 bolt 3" o2 housing any links vendors, ideas would be great Thanks.
Originally posted by jdmawd
you got jokes i see
No I'm serious if anyone sells them it's FP or maybe turbotrix.
ok ill call jeff
Turbotrix gets alot of there parts from FP anyway.
thanks for pointing that out, ill try agp. since the o2 is for their turbo. maybe they can fab me one up.
I'm sure they can.
ADFX Racing has them....sort of... They are 2.5" and open up to 3" and include the whole friggin downpipe. But they are only $225, mandrel bent, stainless steel.
I really have no clue how I found them, but I'm using the same turbine housing as you so I searched the internet for about a month to find one. It's the only one I have found.
you mean this thing
hmm no flex section, not sure about that.
you mean this thing
if you have no other choice. just add a flex section at the bigenning of the straight in the ADFX downpipe.
you can buy a flex section from roadrace and probably any muffler shop.
i know i have seen one, just dont remember where
JDM. I believe I remember Kevin at AGP saying he has these, or will make them.
jeff
jeff
That's what I had hoped, I email him about it a little while age.
We have them. They are not on our site. We are making one right now for a guy. We can make the whole downpipe or just the 02 housing. Contact me if you still need it. [email protected]
You can make it yourself for alot less. My buddy said that the throttle body flange from Road Race will bolt up to the 4 bolt Garrets. All you need is that flange and 2 u bends oh and o2 bung.
I definitely still need it, im open to the idea of a complete d/p o2.
i have no welder or welding skills. i have no problem paying for quality products
Originally posted by 2-0turbo
Victory performance sells O2 housings that will bolt up to Garrett.
Victory Performance sells 5 bolt Garrett housings (not the new Ballistic 4 bolt housing). You might as well try to use a stock DSM Housing...
JDMAWD...did you get back in contact with RNR Racing? How about anyone else? I really like the DP/O2 Housing coming together too idea, but I only need a GOOD, QUALITY Ballistic o2 housing. I even have a flange :D. The only reason I haven't bought the ADFX is I want a full 3" o2 housing...that's it. I mean a 60-1 creates a lot of exhaust gases.
The first section of the O2 housing cannot be full 3", since the flange is not big enough to weld a 3" pipe onto.
Oh, I did not know this. ;)
Do you have a flange in your hand? If you do go get a ruler and measure it. Look real close at the numbers on the ruler. YUP, you're right...it's only 2.89". Wow, now look at the spacing between the bolts, it's 3.25", a 3" pipe will fit nicely on this with just a tad bit of port work (like my flange).
And if you don't have a flange in your hand...you have no clue what you are talking about.
http://www.cheapturbo.com <---they have the same flange as me with a 3" pipe welded onto it for a v-band clamp setup.
Has to start at 2.5" and flare out. No way to get a 3" pipe welded to a 4 bolt garret. It would overlap all the bolts.
He wants one for the GT 4 bolt flange, not a old 5 bolt style.
2.5" is enough. Just flare it out afterwards. I have a 2.5" o2 with a RRE downpipe. Goes to 3" after the flex.
Just get the AGP one, and a 3" downpipe that will bolt to it like buschurs or someone else. Buschur has ran 9s on a 2.5" o2 housing, so go figure.
