q92awd
- 1
- Mar 9, 2003
MissouriUS
Not sure how my last thread was combined with another one, but thought I would start a new one since the other thread changed titles and, therefore, subjects.
First, the car is a '92 awd with 2g mas, 550's, new isc, blocked off fiav and rerouted coolant because the spring broke, s-afc, refurbed ecu, and some other stuff but I think that's all that matters.
Now my problem (from watching the 02 and low fuel trims): My car is running very lean at idle, to the tune of +17 on my s-afc at 1k after the car warms up. The o2's seem to start out fine and then start to get more and more lean as the car warms up. If the car is rolling while it's out of gear (coasting to a stop) the rpm are under 1k and the car is rich on the logger but as soon as the car stops it goes to lean again.
Also, today when I was testing some things I had been driving the car but shut it off for about an hour. When I checked to make sure the new isc was working I started the car and it idled fine at 750 rpm. I then turned on the ac and the idle dipped and there was a click from under the hood. This continued until I shut the ac off - the idle would drop and there was a click, repeating about every 2 seconds (sounded like the ac compressor was making the click, at least near that area). After the car idled for a few minutes I tried the ac again and the idle dropped a bit and then caught at about 600 rpm and stayed there. Turned it off and the idle returned to 750rpm.
If you need any other info, just ask. I appreciate the help.
