exzercist
- 267
- 0
- Feb 11, 2004
Adams,
Massachusetts
I have looked for a t3/t4 Garrett turbo an i cant find one. the only ones i found are the bullseye turbo which are bolt on and will fit the stock manifold. i dont know how reliable these are or if anyone has one. this means its not a true t3/t4 turbo right. because i know t3.t4 have a square inlet where the manifold meets the turbo. where can i find a regular t3/t4 with the same o2 housing exhaust flange but with the square inlet? if i get one of those will i have to dent in the water pipe and get electric fans? because for the bullseye you do not have to. the only sites under t3/t4 turbos in the parts section is dsmmotorsport and slowboy. Is there anywhere else?
