- Thread starter
- #26
98gstJames
- 221
- 42
- May 25, 2022
WInchester,
Virginia
Engine is not misfiring, checked all the cylinders and each one made the rpm’s drop so that eliminated that, I pulled my slave cylinder off the car to see if that would make a difference and the car didn’t shake like it was and was back to normal, I had a buddy push the clutch in while I was under the car and with the clutch pushed in my trans is shifting a little bit, started the car and bam it’s back to shaking, I checked all my mounts and put the bolt I was missing on the back mount in and still the same results, I try to put the car in gear and the pedal is shaking when I start to press it and then the pressure plate sounds like it’s grinding when I start to push the clutch in so that’s awesome.
