DreamChaser7
Supporting VIP
- 634
- 693
- Jul 18, 2019
Valrico,
Florida
I’m working on adding to mine as I can’t wait any longer to start getting this girl together.I'm working on paying off debt. It's so fun!!
2nd gens were really just the greatest. Miss mine every day. Don’t miss blowing up a 47re every year though. One day I’ll have money for a clean intense blue pearl 4 door long box 4x4 and I’ll do a nut and bolt full rotisserie restomod keeping factory appearance except for a 4” lift. Run a 24v and a zf6 or 5600 if they’re still obtainable... yeah it’s a lifelong dream.Finally got around to detailing my rig. She’s been neglected for quite some time and finally got the attention she deserves.
For any curious it’s a 16’ dodge 5500 Cummins. Fully deleted and tuned by yours truly. She has two names “The White Stallion” because she’s a work horse and “Flat Nasty” in honor of my completely blacked out 2nd gen I had that I named “Black Nasty”. I miss that truck everyday and will never find one as clean as she was.
Yeah Chrysler has some of the worst autos. Luckily I did have 5600 truck though. She was a heavy beast though when I put a clutch in it. I used a transmission jack but it was a little intimating dropping it compared to the dsm.2nd gens were really just the greatest. Miss mine every day. Don’t miss blowing up a 47re every year though. One day I’ll have money for a clean intense blue pearl 4 door long box 4x4 and I’ll do a nut and bolt full rotisserie restomod keeping factory appearance except for a 4” lift. Run a 24v and a zf6 or 5600 if they’re still obtainable... yeah it’s a lifelong dream.
I meant extended cab, I wasn’t aware a true 4 door was even made. I can’t believe you let a clean 5600 truck go!Yeah Chrysler has some of the worst autos. Luckily I did have 5600 truck though. She was a heavy beast though when I put a clutch in it. I used a transmission jack but it was a little intimating dropping it compared to the dsm.
The only reason I accepted an auto on the new truck is because it’s an Aisin. It seems to be holding up pretty good so far. It’s about to flip 30k so the manual calls for the first fluid and filter change. The fluid on the dipstick looks brand new but I’m going to change it anyways. Most of the time the truck isn’t empty. Honestly it rides better with weight behind it anyways.
I’ve never seen a 4 door in person. Kinda like a unicorn. Most 2nd gens around here anymore are so rusted and clapped out which makes me miss mine even more.
-Daniel
Yeah they do exist. Look a picture of them up it’s kinda weird looking just because you never see them. But they do exist. That was what mine was extended cab with the suicide door in the back. I couldn’t have asked for a better spec. Black leather heated seats, the woodgrain trim. Long bed with a solid back window and the 5600.I meant extended cab, I wasn’t aware a true 4 door was even made. I can’t believe you let a clean 5600 truck go!
Never worked on a 5600 but the 47 wasn’t light either. Had to do that on an unheated shop floor in February overnight once. Used a motorcycle jack and it still nearly crushed me with the t case.
Now you’ve got me lusting after my unicorn 24v again.
Helping my brother get his affairs in order so we can get his 240sx out of my garage. It's been sitting for 23 years and about to undergo a full rebuild. There's a long story behind this car so I'd like to see it finished moreso than mine. It was one of the first built and turbocharged KA24DEs in the country and the build was halted due to some really bad luck and some really shitty people. Fortunately some of them are no longer in business.You must be logged in to view this image or video.You must be logged in to view this image or video.
. Nope. KA24DET. Unfortunately it seems Mitsubishi is not the only one discontinuing much needed parts. OEM oil pumps are no longer available and aftermarket are junk. He did source a good engine and the oil pump was in really great condition so we'll refresh it and go from there, otherwise dry sump.Please not another LS swap, please not another LS swap...
I thought those came from the factory with the abs light onDiagnosing an ABS light on a 92 Accord. I think I found the issueYou must be logged in to view this image or video.
Sure seems like it. And being OBDI is a little less convenient than just plugging in a scanner that tells me the problem. With Preludes being similar platforms I'm surprised mine doesn't have the light illuminated. Not yet anyway.I thought those came from the factory with the abs light on
I just went through this in my 95 ranger. Replaced just the passenger u joint. 2 weeks later after putting in 4wd for the first time in like 5 years was enough to make the driver lock up too.Had a nasty vibration on my 96 jeep cherokee sport. New front axle u joints fixed it right up.
This looks like fun!The gocarts for the grandkids (and us)
