SixBolt_16G
- 502
- 401
- Nov 7, 2005
Markham,
Illinois
Started prepping engine bay.
Just curious... HOw long did that take? It looks very time consuming
Love your rolling jackstands. Great idea.Started prepping engine bay.
That was about 7 hours todayJust curious... HOw long did that take? It looks very time consuming
Thank you. Serves the purpose. Took a while trying to overengineer something and when I took a beat and dumbed it down came up with those. Just have to go slowly, no slab is perfect. Every now and then depending on where I’m rolling all of a sudden three are under her with solid contact and one gets left behind, . Need to shim accordingly.Love your rolling jackstands. Great idea.
Just a thought- You’ll have to loosen them all a little at a time, or at least the ones that are too close to the runners- so you can scoot the manifold back away from the head evenly and the nuts will come off as you go.Started removing the cheapo manifold, after a couple rounds of PB I broke all nuts loose. I'm beginning to wonder how I will get the nuts off the studs though, it seems like the manifold has reshaped over the studs and I won't be able to remove the nuts without cutting..
Same goes for the turbo side..
Ah that sounds easier.. I was about to get the persuader out..Just a thought- You’ll have to loosen them all a little at a time, or at least the ones that are too close to the runners- so you can scoot the manifold back away from the head evenly and the nuts will come off as you go.
Why do you have all these awesome things just stashed away? best unexpected part I had stored away was a spare 2g knock sensorDigging an old box in storage and found new Drop Engineering motor mount inserts and Royal purple oil filters. I didn't even remember I had those.You must be logged in to view this image or video.
Xmas in AprilDigging an old box in storage and found new Drop Engineering motor mount inserts and Royal purple oil filters. I didn't even remember I had those.You must be logged in to view this image or video.
Took a cruise after work yesterday... Hit boost after rounding a corner... and Boom!... sputter sputter, cough cough.. dieeeeeee of failure........ Same intercooler pipe that blew out of the coupler as last time... . Luckily my wife was with me because I asked her if she wanted to take a quick drive. I was able to push the car down hill through the intersection, while she steered into the gas station parking lot. Then performed some minor surgery. Wife was freaking out, but I knew what the issue was right when it happened. 5 minutes later and I was hobbling it back to the house. So bumper has to come back off on that side today.
On a separate note... Noticed my Oil pressure gauge is buried at over 100 on cold start and warmed up, where it had been previously always been fine.. only bounces when ive been sitting at the light for a few min. Looked at the sending unit and im missing one of the screws on one of the post. Anyone know if i can just buy these little black screws separately or what they are called? Its an old Ac Autotechnic gauge and they dont seem to sell parts anymore. Not sure if these aftermarket senders are universal or not but it looks similar to this glowshift one. Or if i have to buy a new one, any brand thats not garbage?
From an electrical point of view that screw/nut combination is called a "binding post", so if you're missing the black part, that's a "binding post nut". Google image search will maybe help. You're gonna want to know the diameter of the threaded post itself.Anyone know if i can just buy these little black screws separately or what they are called?
