Will Kellermann
- 5
- May 19, 2020
Eagle,
Idaho
Hi everybody, I have a 1ga camshaft angle sensor (CAS) installed on my '95 GSX. It's the silver colored circular CAS that bolts on to the tranny-side of the engine head from the early 1g DSM's.
The Good:
The Good:
- It works perfectly (installed correctly at the right angle, car runs smooth).
- It's in their snug and I can't move/nudge/shake it with my hand.
- It is able to be held in by 2 bolts, but I only have 1 holding it in, which is the one on the right side, if you were staring straight at the CAS head on.
- I have no clue where the other one is and it's been long gone for a while.
- Is it such an issue to only have it held in by one bolt if it's in there tight?
- If not, what is the part number or the size of this bolt so I can buy another?
