1G Barn find won't start
rvllaser
5
Sep 5, 2022
Ozark, Alabama
We have a 1991 Laser 1.8 FWD 5 speed. Car was parked 17 years ago with a bad fuel pump. We removed, cleaned, and sealed gas tank and installed new fuel pump and filter along with new fuel injectors. We have fuel at the injectors and spark at the spark plugs which appear to be in good condition. The engine cranks but will not start.
Cold compression test resulted in 40psi per cylinder - obviously way low. Adding oil to the cylinders raised the compression to 45psi.
Any ideas on what to test next before we have to break into the engine? The service manual says it could be stuck valves or a leaking gasket. We removed the valve cover and the rollers appear to move properly and their is fresh oil being moved into the assembly.
I'm at a loss and could use some help. Thanks.
At this point a leakdown test should help you with where the cylinder pressure is going.
This may give you additional ideas. https://www.dsmtuners.com/threads/how-to-diagnose-a-no-start.217951/
Make sure than when you turn the ignition on the CEL turns on for 5 seconds and then turns off. If it doesn't the ECU isn't functioning and it's not going to start even once you get the compression back up.
Check the timing belt. Since the compression is super low, does not increase when you add oil (not rings) and is more or less equal across cylinders (not head gasket or a single stuck valve, not likely ANY stuck valves if you get SOME compression) it almost certainly has to be valve timing. You can rotate the crankshaft with a ratchet on the crank pulley bolt until the timing mark on the crank pulley is at top dead center (0 degrees or "T") and check the timing mark position on the cam pulley. I bet it's off a number of teeth.
I should have mentioned that the crank pulley will be at it's timing mark twice in a 4 stroke cycle, and the timing gear will be at it's timing mark only once in the 4 stroke cycle- So if the crank pulley is at it's mark and you don't see the cam gear timing mark, rotate the engine one more turn back to the crank pulley timing mark at 0 degrees and the cam gear mark will either be spot on or a few teeth off, then you will know. Please let us know what you find.
CEL light functions normally. On for 5 seconds then off. I’ve read through the no start diagnostic and will see if I can get a leak down tester or have it done. Just surprised that the pressure is so low across all cylinders. Thanks
Thanks. I will check timing and let you know what I find.
Did you disconnect the fuel pump plug and open the throttle during the compression test? I can’t think offhand why the compression would be that low from sitting, though bad valve timing might explain it.
Is this indentation on the crankshaft gear considered the timing mark? I see nothing else on the gear. The repair manual shows it as a triangle. If this is the timing mark then our engine is way off on timing. Thanks.
