Hickory-NC-2Ggsx
Supporting VIP
- 310
- 129
- Dec 27, 2018
Lincolnton,
North_Carolina
This is the Build Thread for The daily Gsx. Reply below.
I see. Yeah better results when you take you time. No need to rush things@AWD-Tony thanks man! It's going a little slower than expected. But little progress is better than none. Also I got that from extreme psi, The brand is Frontline fabrications. All you do is press out a little pin in the oem dip stick and swap out the handles.
How was the install on the shift fork. Just saw these existed and am thinking about upgradingSo I've already rebuilt the trans but I got to tear it back apart to install this new 1-2 shift fork from white shed speed. But luckily the trans is still out if the car. Let me tell ya this thing is machine to perfection. I can't wait to run it through its paces for sure. View attachment 668847
Also here is a few pics of the head going back on today with l-19 studs. I ment to snap a picture of porting the oil port on the head but forgot. I'm taking all the dirty oil covered parts to work with me Monday to throw in the parts washer. And then they'll be off to powder coating. So I can finish this motor out.
