Dashnizzle
- 159
- 143
- Jun 5, 2021
Montana
I have a set of HKS 280 cams for both intake and exhaust. I am now to the point where I would like to degree them in spec with HKS’ data for valve events. Unfortunately I have not been able to find these specs. I emailed HKS and requested the info but all they were able to give me was the max lift. See below:
I believe this information is correct because I was able to find information for 264 and 272 cams which have the same lift just different durations. Here is that info below:
My question is this:
1. Does anyone have a cam card for the HKS 280’s?
2. If not, is there a way to use the lift information and previous 264/272 cam info to determine my valve events so I can degree these 280 cams?
Any information is helpful, this is my first time doing this. Thanks in advance
