all black 4G63
- 254
- 43
- Aug 5, 2019
Chicago,
Illinois
I have been noticing knock when driving around and sometime enough to pass the 5 degree threshold that flashes the MIL at you.
Im just wondering in the log I have attached if this is something to worry about? I notice that most of the knock occurs during low RPM tip in. However, I'm not 100% sure.
I am running the stock turbo with a fully built motor. "weird I know, but the turbo and manifold are weeks out" I have a AFPR set a based pressure 38psi. Im using EVO 8 560's and have not adjusted the DA timing tables much.
Please let me know what you think
Thank you
Thank you
