jw4free
- 84
- 11
- Dec 3, 2008
Billerica,
Massachusetts
Apologize if this has been covered already.
For the gsx pump hanger, can a person weld in this fitting:
And install the pump threaded into the female end with the Radium outlet adapter:
If it’s possible, is there enough clearance for the height of the walbro 450?
2406-06-06
Female JIC x Male JIC Adapter
Radium Walbro E85 Fuel Pump Outlet Adapter (20-0298)
Used to convert the hose-barbed outlet of many fuel pumps to -6AN male. The two billet aluminum adapter halves are secured together with stainless steel bolts that clamp tightly around the pump outlet. A stainless steel retainer and Viton O-ring seal for a leak free connection. All components...
stmtuned.com
