1997DSMALEX
- 40
- 2
- May 28, 2022
California
Hello everyone, I know I’ve seen a few post similar to this but I just want to make sure before I do anything else (take the tranny down) but I installed a new clutch system with a MB010X ACT PP, with a South Bend Stage 3 Clutch and when I had put everything back together the car at first it went into gear when it was jacked up and no tires on as soon as I put the tires on it won’t go into any gear and just grind the reverse but every other gear doesn’t grind at all just won’t go in . I replaced the Master cylinder and Slave cylinder bled the lines and yet anything. I haven’t adjusted the MC rod by the peddle yet but any other suggestions? Also when trying to start up in any forward gear if does want to go forward
