Bud92gsx
Welcome Wagon
- 23,095
- 387
- Jan 16, 2008
Wisconsin,
Wisconsin
Took a bunch of pics for Zimmer of the dsm thats is listed for sale
The wife doesnt know so nobody tell her
I slipped on an icy porch taking the dog out. My leg folded under my large frame. Wish I would have torn acl or broke a damm bone cause this complex regional pain syndrome is no
It will be ok. Our cars will live again one day i understand the blues it can bringPushed it out of the way and closer to the wall so I could get the recycling bin out hahaha... just made myself sad..
7 or 6 bolt.I removed my oil filter housing to port the relief valve to try and bring my oil pressure down. It is over 100psi on cold start and hot idle is 45psi. Free reving to 3500rpm hot pegs the gauge over 100psi hot. Autometer gauge. 10W30 dinosaur juice. I have a Mirage spring to put in as well.
6 bolt. With a 90 OFH. I hope I ported it enough. I should have a new gasket on Tuesday7 or 6 bolt.
Now I have something to do today. Thanks.Just fixed the most annoying window rattling. Plastic clip on front track fell off. Took it off put clip back on and SILENCE!!!! It was so annoying. Now gonna wash her and clean the interior
Excellent detail and work. Those ratchet wrenches are the best6 bolt. With a 90 OFH. I hope I ported it enough. I should have a new gasket on Tuesday
At least the burger was doneMade a new oil return for hx35 yesterday, sweet. Get some groceries today (lots of frozen) and shifter bolt backed out of short shifter just as I was leaving the store. Wife brings some tools quick fix and I'm home groceries saved. She orders a burger and I say "I'm going to loctite that bolt real quick since this happened once before... Locktite on, bolt snaps. Drill it out and decide to tap the next size up as threads took some good damage. drill drill drill... Tap tap tap aaaaand snap... Tap snaps with just a few turns left... well im just now getting to that burger... 6 hrs later
It was rewardingAt least the burger was done
That’s going to be a wicked pissah of a rideToday I got my intake reinstalled after fresh powder coat and 90mm throttle body install. Also put some titanium stud and bolts on her.You must be logged in to view this image or video.You must be logged in to view this image or video.
Its a wet fogger nozzle set up. I believe the tube length is set up that way to maximize equal cylinder distribution.I was going to ask what all that spaghetti tubing was but I see it is for NOS. I would like to see the completed setup. Would it not make sense to have a more direct line to the feed instead of all that twisted tubing?
Do to the placement of the solenoids, I had to run them like that. If it was a 1g, there would be room for straight lines. If you were to look at it from the top, you can see they are patterned. From the side it looks like a mess. I'll post a pic later.I was going to ask what all that spaghetti tubing was but I see it is for NOS. I would like to see the completed setup. Would it not make sense to have a more direct line to the feed instead of all that twisted tubing?
