Fuzzy
Supporting Member
- 54
- 32
- Mar 13, 2022
Chandler,
Arizona
Yo. Hopefully this isn’t a repost. I installed a manual boost controller on my 99 GSX and I’m not convinced it’s installed correctly. The instructions say to install one end to the wastegate and one end to the turbo or intake manifold… but as seen in the 2GB vacuum diagram below the turbo and wastegate are on a t post and the other end is into the intake. Do I remove the T and connect to the turbo/wastegate or do I use the stock tube configuration and replace the wastegate solenoid with the manual boost controller as it’s currently tubed?
