What Turbo is this?
Apacheav8tor
Apr 25, 2022
Jacksonville, Florida
Newbie here. Can someone tell me what I've got here? Part numbers are not helping me on the mighty web. I would really appreciate it. Think I need a new compressor wheel.
Thanks. So do I need to count and measure the blades to see what I actually have?
Lets holler at the resident turbo guru............... @JusMX141 can you help this member out with your vast knowledge??
Thanks Justin!!! :)
Likely some sort of 20G variant...turbine looks to be TD06H. Photos of the damaged compressor would be helpful.
Thanks guys for helping me. Once I figure out what I have, I need to order a compressor wheel and might as well put a rebuild kit on it.
Is this the right one?
I have takeoff cast 20G compressor wheels I'd give you if I'm doing the CHRA service.
If this is going on a DSM that's WAY more turbine wheel and housing than you're going to need, which means a lot of unnecessary lag. This could be a great turbo if you'd switch things up a little.
