ECMlink 1000 cc deatschwerks injector setup 2g DSMLink
Willbill2317
45
May 24, 2021
Cincinnati, Ohio
So i am fairly new to all of this and i wondering if i can get some help with my build in my 2g 99 eclipse gst on getting my car to start up on ecmlink having some trouble with my injectors i think is my issue of why its not starting
I see you’re running a 1g cas. Is it oriented correctly?
Put cylinder 1 to tdc and make sure the marks on the cas line up. Then reinstall. If it still doesn’t start, try adjusting the cas in small increments.
yes it is correct me and my pops actually did this over and over one night and it still nevered started im guessing tune just based on what i took today
Bottom right, you have 3 inputs that are locked. Not sure if that’s the correct settings for 2g
Looks like it was barely running at 200 rpm’s. Let it run and look at your wideband. What’s it reading when it’s running?
Dude it aint running 🤣 that think trys to but does what i showed you in the video in my earlier post now i just took my spark plugs out showed you guys them and down in the cylinders so you guys could see what i am seeing
Not to sure what you are meaning
You’re simulating front O2 signal (narrowband) using your wideband. That’s how you have it set up in link. So the narrowband signal from your wideband has to be wired to pin 76 on the ecu.
Plugs are definitely fouled and engine looks like it's definitely flooded. Clean those plugs and crank it over again.
I can't look at your log from my phone so I will leave to someone else.
It correct and i bought new spark plugs and wires and valve cover gasket today see if that would help but no help i really need someone come out and look at it and also who dey!!!!
Not sure if this will help but here some information of these injectors im gonna post another picture of the data they sent me with the injectors i pretty sure my start up tune is wrong and thats why my car is not starting
more information
I don’t think it’s a fueling issue since you’ve tried supplying brake fluid and you thought it was getting flooded. Was the car running before injectors and SD was installed? Here 1g cas install on 2g to double check
Car ran before i put everything on it. It even ran when installed cams and injectors with regular MAF and bigger turbo and cooler and revised lifters but on the old stock black ecu box. Now it wont run on either but on EPROM it trys to fire up as you guys have see.
The 1 g CAS was installed when cams were cause they're one g cams. I aligned the timing marks up and bought a harness for the 97-99 for it to work
