91Eclipse GSX
- 8
- Jan 6, 2017
ionia,
Michigan
Ive read a good majority of the posts comparing these turbos and spool times im aware spool is greatly dependent on the rest of the setup.Most say if they have old school green or green xl othewise its just Fp green.I assuming most others are talking about the Fp green 73htA 54lb per minute. But how does the 73htA compare to the current version of the green the 73htZ rated at 57lbs. Obviously the 73htZ is good in theory for 30hp but are the spool times between the two the same one quicker then the other? FP website says its the 73htZ wheel in one area the then 73htA. But im guessing theres a difference to gain the 3lbs per minute. And they havent adjusted website yet. Also the newly listed hta68 v3 on holiday sale hows spool compare to v2. Might be the same turbo just mhi 8cm turbine housing vs v2 with fp 8cm turbine housing? My thoughts are my ideal turbo is Fp hta68v1 but since it no longer made I was looking into v2 but the general consensus is it spool much slower then v1. The v2 spool similar to a green a little faster but the green is good for alot more power so im getting convenced to go green. Also know the hx35 is very popular but I do Not want to run a hx35 for multiple reasons. Mainly looking for spool times or technical data between the hta68 v2 vs v3 and the green 73htA vs 73htZ. Thanks
