Mham2k
- 306
- 57
- Feb 8, 2008
Dallas,
Texas
Something is wrong, I just don't know where to start.
IR boost controller
2 Port Wastegate
ECMLink
So everything worked fine on my last build, the boost controller, ecmlink, wastegate ect
My wastegate pressure is 10psi, I have tested with no controller hooked up
When I hook up the IR controller it gives me all the boost. It won't let me turn it down.
I have ecmlink setup correctly, I know this because this same settings worked on my old build. Disabled error correction, enable boost control, both tables set at 0.
Where do I start? IR selenoid?
It's hooked up based on the VFAQ 2 Port diagram.
IR boost controller
2 Port Wastegate
ECMLink
