EC17PSE
Freelancer
- 5,895
- 3,489
- Nov 1, 2008
London, UK,
Europe
Hello everyone and I am back once again with a new product.
How to install here https://www.dsmtuners.com/threads/how-to-install-bobbys-v2-bumpsteer-kit.534100/
This is the V2 bump steer kit for the 2G and which takes what I learnt from the V1 kit, This takes that and works around those foundations to make it all around stronger, better and all around complete custom setup.
new benefits include,
* 1 piece outer shaft (EN24T)
* revised outer spacers which offer an easier outer dial of adjustment and over a wider range
* 1 piece shaft now allows you to go 1.25mm closer to the steering arm meaning more can be dialed out the lower your car is
* upgraded outer rod end size which adds more strength then previous (still the high quality kevlar/telfon lined chromoly units I always use)
* strong middle adjusting shaft
* brand new high quality inner tie rod end which is stronger then the oem units
This kit comes as a full replacement from everything from inner to outer tie rod end! its a 100% complete kit for you and it even comes complete with a brand new inner rubber bellow covers so everything is covered and no trips to the hardware or parts store needed! you will still do the adjustment from the inner toe rod as before, the outer rod end can be adjusted if required but its not the primary adjustment.
the shafts and adjuster will be plated for corrosion resistance.
this kit is not designed for cover boots over the rod ends but you can if you wish buy these to give some protection https://secure.chassisshop.com/partlist/15344/
Price is $480. This is based on 20 sets as a batch and is also shipped to the Lower 48 states only, anywhere else please PM me for a quote, Canada tends to run a small amount more but not much more.
Payments will be split into a deposit and then full upon closing the list
NOTE current to currency at this time, currency may change for other batches
* Deposit of $180 then remainder of $300, when sending will also require full shipping details and phone number to save any delays in shipping out.
if you have any questions then please do feel free to ask them. This will stay open till 28th FEB and the monday 1st i will place the order for the machine work to be done. if the list fills up faster and
LIST.
1. @elocneas (P)
2. @SlowZRally (P)
3. @calgst95 (P) + Droplinks
4. @spyderdrifter (P) +Droplinks
5. @DSM98GSX (P) +Droplinks
6. @95Talon1000 (P)
7. @Turbo_Timmy (P)
8. @josh408 (P) +Droplinks
9. @talon91tsiawd1 (P)
10. @DSM Zo (P)
11. @TommyDSM (P)
12. @tunernewb92 (P) +Droplinks
13. @T2Small (P)
14. @BizkitGarcia (P)
15. @96dsmftw (P)
16. @Eclipse 1998 (P) +Droplinks
17. @boostjunkie24 (P)
18. @Tyear (P)
19. @jpmxrider489 (P) +Droplinks
20. @GSXlusive (P) +Droplinks
21. @efrainz28 (P) +Droplinks
LIST.
1. @elocneas (P)
2. @SlowZRally (P)
6. @95Talon1000 (P)
7. @Turbo_Timmy (P)
10. @DSM Zo (P)
11. @TommyDSM (P)
13. @T2Small (P)
15. @96dsmftw (P)
18. @Tyear (P)
