- Thread starter
- #76
randman2011
- 552
- 282
- Feb 26, 2012
Indianapolis,
Indiana
While checking out the exhaust situation I noticed that the left rear half shaft inner CV boot was leaking. After confirmation that my local axle shop can have it rebuilt this week I pulled it today.
I pulled it out through the knuckle opening. It probably would have been easier to pull it through just enough to clear the differential then slide it back out, but whatever. It is done now. It's a REALLY good thing that I replaced this whole hub last year because it came apart very easily. Also I pulled off way more than I needed to. Ignore the disconnected trailing (?) arm.
Missing the CV boot clamp. Surprisingly there is still grease inside in spite of how much clearly leaked onto the differential and subframe.
But this is no bueno. The c clip is completely missing, and the shaft has slipped out of the differential at some point in the past and damaged the threads as a result. God, the previous owner of this car was a real piece of shit.
This all needs to be back together because I've got help coming this weekend to install the sway bars with me.
In unrelated news, I am rebuilding my first turbo! This was the celebratory picture when I finally got the turbine housing off. It's a 60hp turbo from my van and it's so tiny! Unfortunately that only makes it more difficult to rebuild. I bought the ONLY RHB3 rebuild kit in the entirety of the US according to GPopShop. And I accidentally destroyed one of the components so they're drop shipping me a ~10mm "piston ring" from the manufacturer today. I'm bad at this.
EDIT: Also, STM STILL hasn't responded to my email or answered the phone.
