1G GM/SATURN ALTERNATOR PART#?
MCR can make a 1-wire or 3-wire. Don’t do a 1-wire. There’s no benefit.
BTW, the part number is cs130 I believe.
My current setup has one wire from alternator to alternator fuse so I’m assuming that’s what I need
The 1-wire setup is suboptimal and is only around because it conveniently only requires one wire instead of two. You can make your own 3 wire setup like the factory or just plain use the factory harness if it's still there.
