2G Single & dual stage MBC not working after rebuild
Jcoylesr76
Apr 8, 2019
Athens, Pennsylvania
ETA: unless I am mistaken and stock psi on waste gate is 14-15psi?
Greetings,
Having issues with boost control, car was recently fully rebuilt, old MBC was funked up so I picked up a turbo smart dual stage, and no matter what I do it's still hitting 15psi. Info i got was 9-11psi on stock wastegate for this turbo? And help would be appreciated, some info below. Thanks.
EvoIII 16g
255 walbro
550cc injectors
Punishment racing FMIC & piping 2.5"
Injen intake
Black box ECU/Tactrix tune.
Block:
Manley forged crank
Turbo tuff rods
Manley stock size/comp pistons
All new bearings
Balance shaft deleted
Fadenza flywheel
CC stage 4 6 puck clutch and pressure plate
OEM TOB.
Head:
Crower SS valves, strings, retainers, and titanium tops
GSC 268/268 cams
New valves seals, rings, and gaskets, etc
Kingly HLA
I've not encountered an Evo 3 16g with an internal wastegate actuator set for less than 14psi. The stock t25, on the other hand fully extends around 10ish in my experience. An Evo 3 16g is just getting started at 10psi, most wouldn't want an actuator that low opening on a 16g.
do you need foils particularly? i’ve been making some swaps to my foiled cube and may be able to help out
Kodi nox
