What happened to my bearings?
88BB8B
179
18
Oct 14, 2016
Coldstream, BC_Canada
Hi everybody. My car had a full stock rebuild less than 100km ago. New crank, bearings, pistons, rods, and rings. I noticed a little bit of glitter in the oil on my dipstick so I decided to take the oil pan off and inspect the bottom end even though the engine wasn't knocking or anything. I found 3 or 4 silver flaked in my oil filter, not mostly just dust. I took off my oil pan and found this.
so I took my rod caps off on cylinders 3 and 4 and the bearings looked like this.
Cylinder 3
And Cylinder 4
there are lines in the crankshaft that I can feel with my fingernail, AI it's toast. My question is what could have caused this. I did at one point drive very gingerly for about 5 minutes with some oil that was somewhat flooded with gasoline, could that cause bearing failure this bad with such low mileage on them.
Just to clarify if the pictures I'm aren't clear enough I can see at least some copper material on every bearing, with the bearing on the right from cylinder 4 having virtually no silver left on it.
Last question is, fortunately I caught this very early, the engine wasn't making abnormal noises, it was on a basically brand new rebuild, so you wouldn't think this sort of thing would be going on in there but my paranoia got the best of me. Do any of you think I could I get away with just a new crankshaft and bearings, seeing as virtually all of the particulate I have found is very very fine, almost dust? Or will this just happen again if I do that?
Bet, just like @bastarddsm said, it was assembled dirty. Cleanliness is next to godliness in motor builds and other things, always. I will say they didn't clean out the crank dead end journals before assembly, but it is all just a guess unless you can pin down the cause during teardown.
Dirty assembly.
When a machine shop machines a block it’s not final washed for assembly, that’s up to you. If a white cloth with wd40 on it is anything but white after wiping cylinder bores you have honing grit to clean out of them.
Wow, thanks for all of the replies guys. So everybody thinks it was assembled dirty, and if I take it apart, clean it properly, replace the crankshaft and bearing, it should work after that? Can I clean it myself? I found a good deal on a crankshaft and some bearings but I can't afford much other than that. I'm gonna reuse the pistons and rods (assuming they are okay to reuse at this point) because they are brand new.
The job doesn't sound too terrible. I'm mostly just concerned about the cost. Ordinarily would the pistons, rods, rings and wrist pins be reusable after something like this?
I found a crankshaft that comes with bearings, its from crankshaft supply, anybody have any experience or knowledge with their quality?
I would never reuse rings. Maybe its me. Everything else you mentioned I would have no problem cleaning up and reusing. When you get the crank, mic it to see if it is machined correctly. If you can't do that, then at the minimum, use plastiguage when putting the mains and rods back in to know your approximate clearances......and write them down, you will forget after a month or so.
I was thinking maybe new rings as well, that's maybe the one other component I could afford, I would love to throw some OEM evo 8 pistons and rods in, because I hear they'll hold about 500hp anand I would love for this car to be at about 400hp when done, but I don't know if the cost of those is in store for me.
Replacing the piston rings would just mean honing the cylinders again and breaking the motor in properly on top of everything else mentioned, right?
Also, the crankshafts on a 95' eclipse GSX and a 95' eagle talon tsi AWD are exactly the same right?
A rehone and brake the motor in. Yes a 95 Talon TSI has the same crank as the 95 GSX.
Thank you. So update I pulled cyl 1 and 2 rod caps off, and the bearings looked about the same as 3 and 4, but I had to pull off the little gearnie thing to get at em, and on the top side of it I found this.
It is magnetic material. My best guess is that its either honing material, although I have no idea how a supposedly "professional" shop could think that its okay to leave material like that in the engine before reassembly. Or it's cylinder material that has been worn off the cylinders during break in. Or maybe I'm wrong.
Does this point to any other particular cause for this failure to any of you?
Will I probably need to replace my balance shafts/ B/S bearings, or do you guys think they'll be okay? Also it felt like my rod caps may have been over torqued when I pulled them off. The correct torquing on them is 18ft*lbs + 90°-100° correct? It felt like they were torqued to over 100 ft/lbs, could severe over torquing cause the bearings to not clear the crankshaft properly?
They'd be so tight it would be hard to turn over. I have a video that shows I can spin a 4g crank, without rods on it, with a battery powered drill. It should be snug but not to tight.
I noticed when I would shut the car off it seemed like the engine stopped quite quickly compared to other cars I've owned. Could just be the grindy bearings I suppose though.
Update on this situation. Block has been cleaned honed, clearances checked (except for pistons) I have some eagle H-beams, and some OEM evo 8 pistons on the way, (I know everybody is going to tell me to go forged, but I've considered it and I think this engine will probably last longer and be more streetable at the power levels I'm shooting for with a good strong cast piston.) I'm going to cut the pistons for spiralocks. new rings, ACL race rod bearings, ACL aluglide mains. Surprisingly to me this block was in really good shape, the cylinders are almost exactly stock bore, very minimal scoring, all clearances seem to be in a good spot for what I'm planning for this motor. 0.0018"-0.0021" across my mains and I checked one rod with pastigauge and it was right around the 0.002" mark I'll be running 40 weight at least. Once I get this thing going I may add a meth kit since E85 is not available here. Probably will need to consider drive train upgrades before that.
Those oem pistons don’t work with eagle rods. The oem pistons have no grooves for the pin clips. In a stock setup the pins are an interference fit in the rod. The eagle rods have the pin floating.
I have access to a machine shop and plan to cut groves into the pistons. The OEM evo wristpins are beefy as heck and look like they'll work no problem with the Eagles.
Here's the block today after paint. Just needs a final cleaning before assembly.
Lmao, just realized looking at the picturea, I forgot to unmask the frost plugs
