88BB8B
- 179
- 18
- Oct 14, 2016
Coldstream,
BC_Canada
Hey everybody. I've shearched and searched and cant seem to find a definite answer. Everybody will tell you if your rod or main clearances are too large, you wont have sufficient film and spun bearings and seizure will insue, however, when it comes to a full floating setup, specifically the piston bore to wrist pin clearance, if the clearances were way too big for exaple, and you lost the film between your piston and wristpin causing seizure, wouldn't everything kinda just be fine? Like the wrist pin would be seized in the piston sure, but not in the rod end.
So why does it matter if your piston to pin clearances are off?
