SwiftKidGSX
- 100
- 7
- Jul 11, 2003
Cerritos,
California
I was in the process of cleaning out the inside of the gas tank and was removing these bolts. The first one came loose as normal and removed which was the top one. The next one just spin in place and was not coming out, it actually got WARM and HOT the more I spin it, what gives? When I tried to tighten it, it gave the same result, it also just spin.
Now that the top bolt is tight, will I have any problems leaving the bottom one stripped? It had a sharp shaving on the side on that bolt, so I know it stripped, but why?!
Are these held by a bolt or something from the underside?
Thanks in advance!
Thanks in advance!
