2G Loosing coolant
kteare
11
Jul 14, 2019
Ankeny, Iowa
I'm not a coolant expert and I'm posting here for some desperate help. My 97 GST is presumably loosing coolant through the overflow tube on the reservoir. I say that because I'm seeing coolant on the garage floor from the tube. The oil looks good so there isn't a problem there. I can top off the system, drive 10 miles, and after the drive, the reservoir is empty and they system is missing nearly a quart of coolant. I apologize in advance if this is already addressed somewhere else (I didn't get a search hit). What would be causing this issue? Thanks!
The Stealth I bought for my daughter years ago had this problem which boiled down to a corroded thermostat housing where the radiator cap was supposed to seat. It was so chewed up it couldn't seal and just blew all the coolant out when it ran.
UPDATE: The cap didn't fix the issue. I took the GST our for a short run of 100+ MPH and the reservoir is empty. There is fluid all over the garage floor at retry. The overflow tube is dry, the radiator connections are dry, but I can't figure out where the massive leak is coming from. Any ideas where to check?
Every single DSMer needs a coolant pressure tester. Pressurize the system to 15psi and let it sit. If there aren’t any leaks it will hold. If it doesn’t get some soapy water and start spraying.
Any recommendations on a worthwhile kit? With my luck, I'd buy a kit that didn't have a converter for the DSM neck. Yes, I'm one of those guys.
Then replace all the hoses, therm, take the therm housing off and inspect and replace it w fresh rtv. Replace all your coolant hoses if they arent already brand new. Get the heater and tb hoses too! It can only be so many things. And its good maintenance too. I recently did all mine. Peace of mind.
That seems like a bad leak. Guessing it leaks when it’s pressurized. You should be able to find it with a pressure tester but I’m surprised you can’t see it. There aren’t too many places it can leak from. Start feeling around from the highest point.
Under the throttle body
Thermostat housing & neck
All the lines
Oil filter housing
Radiator
Turbo coolant lines
How old is the thermostat? Coolant would boil out of my reservoir at a stop after it’s been running in the highway on my jeep. It turned out my thermostat wasn’t opening all the way. The thermostat was 5 years old.
Jegs has a decent kit. Nothing in the system matters if it doesn’t hold pressure.
I agree and disagree. If the thermostat isn’t opening all the way, it will overflow out of the reservoir.
