sinned4g63
- 320
- 87
- May 1, 2017
Pasadena,
Maryland
Yep, I know it's been beaten to death many times. This past week I changed out my valve cover because it was cracked by the bracket that holds 2 of the spark plug wires on the bottom right corner of the plug well, the well usually had some oil sitting in it and I knew it was cracked from when I tried to paint it many moons ago. Now that I've got a replacement on being overly careful tightening the bolts because that's how I cracked the last one, I'm still getting oil in the plug well. I've wiped it off multiple times only to find more oil is being pushed from the cap itself. I tightened the hardware to stop it coming through the middle nut/bolt, but is continues to leak from under the cap. I got a new gasket and doubled up but still nothing even though the cap feels a lot tighter. When changing the valve cover I did also have to re-use the PCV at the top left corner but I blew through it and it seemed to be working as it should. The cap is probably a year or two old so I'll probably replace it and throw the new gasket on but I'm not sure what else I can check.. I have been searching for solutions on the issue periodically throughout the week but am having difficulty seeing people share their solutions and how well they worked.
Thought about getting a Mishimoto cap or something but that would be a shot in the dark, I'm not sure an aftermarket cap is the solution quite yet.
