87dsmer
- 1
- Feb 5, 2020
Beechgrove,
Tennessee
Figured I would go ahead and post while I continue searching. So I'm in the getting close to finishing swapping my 93 5 spd 4g37 over to a a 4g63nt. The donor car is a 91 auto. Motor is all in and things are pretty much plugged up but it's not cranking and I dont hear the fuel pump. Right now I have the mpi relay from the auto plugged in since it's a different plug but I'm thinking that's my problem? Also I was reading about matching auto/manual ecu numbers from the parts list thread with federal and California numbers but the ecu from the 2.0 auto is a remanufactured unit and just has number : 2-6205 and calibration code: 0901TG so I'm not sure if this ecu will even work for me
