2gdanny
- 626
- 17
- Mar 9, 2007
south river,
New_Jersey
Time as come and I’m in no rush but here it is
1998 eclipse gsx 5 speed trans 6 bolt.
2.0 built block wiseco pistons, crower rods kiggle main, arp all around and acl bearings.
Polished head, Ferrera valves stock size bronze guides kelford 272 cams, kiggle dual bh springs, 3g lifters, hks can gears with hks timing belt.
5 speed trans, built by dogbox racing local, evo 3 gears all synchros coated spider gears center diff, ptt twin disk clutch with a breaded line from slave to master.
T case was oem rebuilt by jacks
Stock axels and stock drive shaft.
Megan race and street suspension, aluminum upper control arms with caster adjustment all bushing, motor mounts, bolts nuts have been replaced with new ones.
Magnus cast intake manifold
Magnus fuel rain
2150 fic injectors -6 feed and return to a intake 450 re wired fuel pump
Battery mounted in back with proper terminals and fuses with a kill switch and 250amp breaker.
1off turbo manifold t3 twin scroll with dual waste gates too mount with a6466 t3 twin scroll.
S90 throttle body with a v-band to 3”
Valve cover is baffled with an fittings to a catch can
aluminum intercooler piping
Full 3” exhaust with v bands to a thermal research muffler all welding and piping done by beanfab.
Oem breaks powder coated and a full breaded line from boater to caliper with a abs delete kit
Rotors and pads where done 2 years ago and I haven’t put more then 50 miles on it
Rpfi with nittos nto5 100% intact one wheel got damadge after falling over ,
95% is powder coated
Interior is black carpet with real bride seats tekata harness and a harness bar
Momo steering wheel
Aem gauges
All speakers replaced and radio
Any other questions just message me I’m sure I missed something
I’m looking for $15.000 or best offer I also have bins with extra parts worth 2k that will go with it interior stuff extra cams, tein suspension, turbo manifold, radiator and other stuff
Magnus fuel rain
Momo steering wheel
Aem gauges
