ECMlink 2g setup help
SasaniFab
2,433
782
Dec 1, 2013
Mexico, Connecticut
For the 2g, the map sensor... when using the ecmlink cable do they use the Baro or mdp input? I’m having trouble getting this 2g to run with the omni 4 bar
Baro, if you meant the ecmlink cable is the SD cable that is connected to the MAF sensor connector.
Simply trace the MAP signal wire to make sure. If the signal goes to the stock MAF sensor connector then it's baro. If it goes to the MDP connector on the intake manifold then it's MDP.
I know it'll probably not be this but do you have iat connected or zero out the temp sensor reading? I just did mine and I knew I didn't need it but I forgot to set to zero since do not have one hooked up and car started after I changed the setting. Just making sure all bases covered
