SasaniFab
- 2,433
- 782
- Dec 1, 2013
Mexico,
Connecticut
So my stupidity continues despite what I tell my customers... What is the saying ? Practice what you preach.... How often do you guys check for boost leaks? I can’t confirm when the leak started but I found a massive leak on one of my secondary rail welds. A part of me thinks a poor weld got worse when I had the nitrous backfire that nearly exploded my manifold. I welded this before I was proficient at welding aluminum so ... The manifold is ballooned on the backside but didn’t crack so I’m going to keep using it. I made a welding jig that I can also boost leak test on so I can test it off the car.This probably explain my issues with stalling late and idle issues....
