SasaniFab
- 2,433
- 782
- Dec 1, 2013
Mexico,
Connecticut
The engine I built was experiencing some timing belt wander and it also effected the tension on the belt. Normally when I build a motor I use a brand new tensioner arm. Unfortunately for us 6 bolt users it’s becoming harder and harder to find them. Luckily I was able to find some more for my stash. To fix the issue I ground down the dimple flat so that the timing tensioner could sit flush. You also need to make sure that the plastic bushing is in good condition.
