AWD-Tony
- 6,801
- 3,735
- Sep 11, 2017
Cincinnati,
Ohio
Anyone know how to repair this? If I push the two sides together, it’s clearly missing material.
That was a perfect video of foam repair . Mr Hall went step by step through the process you need to take to repair your foam bolster . I really like that he added the material to the underside of the foam to add strength . I always use heavy canvas in that area . The foam used in this type of repair should be of high density . Mr. Hall is using a electric meat carving tool to cut his foam. The idea is to let the contact cement dry enough where it becomes tacky before you stick it together. .Make sure you have some Varsol paint thinners handy when using the contact cement. . I think the video pretty much covers this problem .
That is way to much money for this small job. Heck.. you could drive to my shop and I would fix it for nothing and drive home and still have money in your pocket for that much . ..Before I retired I charged $500.00 to repair the foam and make new cloth covers on a pair of buckets . If you wanted real leather of coarse it would be more .I`m sure you can handle this project yourself @TK`s9d2TSi . Just follow the video you posted from what I call YouTube University .Make sure to post a pic of your work ..
