DSM_15_2G
5+ Year Contributor
- 39
- 17
- Dec 6, 2018
Serbia,
Europe
Whats up DSM fam, got some more issues I have to fix
Ever since I got the car, always had flimsy light output, despite installing the 80$ led bulbs into the OEM headlight, it was much better but never "that good" . As we all know, LED bulbs give pure white with a bit of a bluish tint to it color. In my case, it was pure white with yellowish tint to it. Gave the bulb to a buddy of mine and it had the bluish tint to it.
Buddy of mine sent me his retrofitted headlights with newer Honda Accord projectors with some random LED bulb which I saw was bluish color. I decided to hook them up to a battery 12.4v power source to test before installing them. They were really bright, cutoff line was sharp with a bluish tint to the top of the line.
As soon as I installed them onto the car, I lost 80% of the bluish tint, they lost the cutoff line (not as sharp) and have lots of yellow tint to them..
Maybe I could replace the headlight relay? Maybe headlight ground is bad? I did notice that ECU ground which is located on the "rusty" radio bracket is really rusty but idk if that affects anything
I need to say, all of the lights on the car are a bit dimmer than they should be (including interior etc.) not dim like really dim, just not 100%
Alternator is 90 amp one from a auto spyder charging 14.4v
Can anybody explain to me what the f* is causing this shiiiii.
I am swapping the whole front end harness very soon anyway, but just want to know what could be causing this as I really am speechels about this
