1G TB blocking vacuum ports
Adrian97
5+ Year Contributor
100
2
Mar 3, 2018
Göteborg, Europe
Hello!
I have 90 TB and I wonder if these ports can be blocked with hoses in this way
(its not my TB) is there any difference between hoses or caps ?
Yes you can block them just as shown in the pic. Hose is cheap and easy, caps are more expensive but cleaner. We're talking differences of less than a dollar though.
FWIW I had my TB ports blocked with hose just as the picture you posted.
Be careful if it's truly a 1990 turbo throttle body. Looping them can cause a throttle plate bypass and, thus, idle problems because one of them is after the throttle plate.
See: confirm 90 TB ports
Yes, its truly 90 TB, so in this case will be block 4 nipples with vacuum caps, not hose?
