2G New Speaker and Amp
Moosewala
Jul 19, 2020
MUMBAI, California
Hello everyone,,,
Hello fellow Diamond Star Motorists. I bought my DSM on August. Since then I've been fighting a bit with it. So here is my issue. I Installed an Infinity Kappa 1200 W AMP on the car. Brand New 4 speakers and 2 tweeters. Whenever I press the throttle and go into boost I get interference noise. Almost like the turbo runs through my speakers. Plus is there anything I can put between my rear speakers and the car metal. Whenever I run the volume over a certain level the speakers vibrate. If you need the model of the speakers I can find it still have the boxes in the car https://100001.onl/ https://1921681254.mx/ https://happymod.site/.
You are experiencing a ground loop which causes the whining noise that reacts to the throttle/alternator. This could be a bad ground (non clean metal) or if you run the rca cable along side the power wire the rca can pick up interference from the power wire more common in less quality shielding in the rcas. Usually when only running a sub amp you wouldn't notice the interference but since you are running mids n highs amp it is noticeable. Try cleaning grounds at amp and battery and the location how you route the rcas. I usually run them down separate sides..or they make a ground loop isolator that plugs inline with the rcas but those dont always work. Sorry for long msg but to test you can jump a ground wire to the shielding part of the rca which is the outermost part of the connection not the center prong. Again sorry and thank you for your time, Jason Penny
This is absolutely a ground issue and the most common reason for engine whine in a sound system. Metal to metal ground connection and RCA cables ran down one side of the car and power down the other fixes this issue 80% of the time. Sometimes it can be caused by a weak connection in the radio ground as well, but not too common.
As far as the speaker rattle at high volume throw some dynamat around them and make sure they are very securely screwed in. Sometimes the plastic where they mounting screws go gets warped and makes the mounting a little sketch.
