SasaniFab
- 2,433
- 782
- Dec 1, 2013
Mexico,
Connecticut
Hello boys , my buddy’s car came back for some work and I had the pleasure of repairing some striped threads on the timing cover rail and block. This is what I use to repair threads on anything I’m fixing.... In this case 6x1.0mm time sert kit , 5mm depth inserts and some lock tight , it’s really tight on the car so I used a tap wrench adaptor for a socket drive and used my Milwaukee ratchet. You could probably get away with using longer time serts in certain areas but the timing cover side under the belt is extremely shallow. 5mm is your best bet imo
