GSX
thanks for coming back! be sure to post many videos, pics and keep us all up dated with your car as its good to see a 1G out on track
Thanks guys, current plans are to pull the 6bolt motor out of my laser and just do a refresh before swapping it in. I'll also need to swap in the 4-bolt rear as well, then there is the old FP green to replace the tired 14b, then there is the fuel system, then a Link ecu... but just one step at a time...LOL I want to get back on track soon and see if it truly was a warped head causing my overheating issue.
I only got about 7 laps in at the track but it handled pretty good. I have a lot of work to do to get it ready for next year.
here is the info for the custom rotor hats I had done for the cobra brake setup
Discovery parts did them it took about a month to get them, because they do race and they need the time to build the CAD file they send off. The hats dont fit the rotor perfectly I still had to use some hub centric ring adapters other than that they were a perfect fit. They were about $300 each and here is the form I used and the values: https://discoveryparts.com/custom-2-piece-rotors/5400-custom-brake-rotor-mount-hat-form.html
A: 212mm (this could be different based on your rotor selection)
b: 160mm
c:70.9mm
d: 4mm
E:7mm
f:3mm
g:7mm
h:174mm
i: 8 holes
i;8mm
i:XXXmm ( i screwed this one up and had them re-drilled)
J: 5 holes
J: 15mm
J: 114.3
Here is where I got the rotors from and I went with their race versions:
http://www.fulltiltboogieracing.com/1999-2004_Cobra_Brake_Parts.htm
Also to be on the safe side I had to shave about 3mm of the outside pads where they come close to the rotor hats.
b: 160mm
c:70.9mm
d: 4mm
E:7mm
f:3mm
g:7mm
h:174mm
i: 8 holes
i;8mm
J: 5 holes
J: 15mm
J: 114.3
That's pretty slick. Those are probably pretty similar to the TCE front rotor set up I had on my 1g.
