1G Timing belt wear
Justyn
4
Sep 30, 2019
Toronto, ON_Canada
Hey everyone. Today I took off my upper timi g belt cover to find wear on my timing belt. I changed the timing belt about 5 months ago due to the same reason. I would like some input on this and what could be causing the abnormal wear.
Thank you.
Curt-s and Lucky13. Man you guys are right on the money. Took it apart and found the screws are too long. Thanks guys.
If you have the original oil pan bolts two of the bolt heads are different if i recall. This is one of the main things I point out when people ask me about factory manuals. They mention this on the oil pan. I belt Chilton doesn't.
Sucks you have to do another belt.
I dont have another belt. You think I should be good without changing it for now?
